Touch doorbell circuit diagram
Source: InternetPublisher:三岁就很酷 Keywords: Circuit diagram touch type doorbell circuit Updated: 2021/09/22
The touch doorbell introduced in this article uses touch instead of mechanical switches. It is simple, reliable, practical and interesting.
Working principle: The circuit schematic is shown in the figure. The 555 time base integrated circuit works in a monostable state, and the ③ and ⑦ pins are usually low level . When touching the metal sensor piece M with your hand, the human body's induction signal is added to the 555 time base integrated circuit through a 0.1μF capacitor. Pin ② causes the circuit to flip into a temporary stable state. At this time, pin ③ outputs a high level and is directly added to the trigger end of the doorbell chip. The chip is triggered and drives the speaker to sound through the transistor. At the same time, pin ⑦ also becomes high level, and the power supply charges the 4.7μF capacitor through the 100KΩ resistor. When the voltage on the capacitor is charged to 2/3 of the power supply voltage, the circuit flips again, the temporary steady state ends, and pin ③ becomes low again. flat. When M is touched again, the above working process starts over again. So every time M is touched, the doorbell is triggered. ③The 0.01μF capacitor on the pin is an anti-interference capacitor, which can prevent the doorbell from being accidentally triggered.
![Touch<strong><strong>Doorbell Circuit</strong></strong>](http://www.eeworld.com.cn/circuit/upload/3de5864af3473c8ca922ff3587f3c63e/36a29fff4f45adcc1527301e2f026690.jpg)
Component selection and production: The doorbell chip of this circuit uses the "Ding Dong" (HL9300) chip. Every time it is triggered, even after the ③ pin becomes low level, it can still make three consecutive "Ding Dong" sounds. If you choose a chip (such as a music chip) that requires the trigger terminal to be always at a high level before it can sound, you should appropriately adjust the resistor-capacitance time constant on pin ⑦ to adjust the temporary steady state time, so that the high level of pin ③ is sufficient Make the chip emit a complete piece of music before turning to low level. In addition, the base potential of the push transistor of the doorbell chip should be measured when the doorbell chip is powered on. If it is low level , then an NPN transistor should be used as the push tube. The purpose is to prevent static dynamic consumption and extend the battery life. When the lead of the touch piece is too long, it is best to use a shielded wire and ground the shield. This circuit is simple to make and can work normally as long as it is installed correctly. This circuit can also be expanded into practical circuits such as touch switches and touch alarms.
- TA8164P FM Radio
- Circuit principle and production of six-tube radio
- TA7792 Medium Wave Radio Circuit Diagram
- Convenient and practical electric guitar wireless transmitter
- RX3408 FM/FSK 500~20 MHz Receiver
- RF2942 I/Q 915 MHz Transmitter
- Radio coding transmission circuit composed of MICRF102 and PT2262
- GPS RF front-end circuit composed of MX2740
- XE1203 FSK 915/868/433 MHz Transceiver
- F05A/B/C Series AM 433/315 MHz RF Transmitter Module
- How to learn circuit diagrams?
- As a qualified engineer, you need to remember these circuit diagrams throughout your life!
- Common double-tube energy-saving lamp circuit schematic diagram
- Mobile phone production of remote home appliance remote control circuit diagram
- Energy-saving motorcycle rectifier regulator circuit diagram
- Car power supply voltage monitoring circuit diagram
- AC grid powered light emitting diode circuit diagram
- Two smartphone charging circuit diagrams
- Laser flashlight circuit diagram
- JB35 module external circuit diagram
