As a qualified engineer, you need to remember these circuit diagrams throughout your life!
Source: InternetPublisher:吃掉星星 Keywords: amplifier circuit analog circuit circuit diagram Updated: 2021/11/23
1. Signal filter
1. The function of signal filter:
Differences and similarities with power filters:
2. Impedance calculation of LC series and parallel circuits, amplitude-frequency relationship and phase-frequency relationship curve.
3. Draw the passband curve.
Calculate the resonant frequency.
![To become a qualified engineer, you need to remember these circuit diagrams throughout your life!](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/ee6510510cbd40530a12aef21a5e728e.png)
2. Differential and integral circuits
![Differential and Integral Circuits](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/61472b7c90fcbdb5ea22d6477f1f3079.png)
1. The function of the circuit, the differences and similarities with the filter.
2. Analyze the voltage change process of differential and integral circuits and draw voltage change waveform diagrams.
3. Calculation: time constant, voltage change equation, selection of resistance and capacitance parameters.
3. Common emitter amplifier circuit
1. The structure of the triode, the current relationship between each pole of the triode, the characteristic curve, and the amplification conditions.
![Differential and Integral Circuits](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/bc8c96b215f00a2b0acaae7b29447cc7.png)
2. The role of components, the purpose of the circuit, voltage amplification factor, input and output signal voltage phase relationship, AC and DC equivalent circuit diagrams.
3. Calculation of static operating point and voltage amplification factor.
4. Voltage-biased common-emitter amplifier circuit
![Differential and Integral Circuits](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/0f901146a08090b21eb330aef831d1c8.png)
1. The role of components, the purpose of the circuit, voltage amplification factor, input and output signal voltage phase relationship, AC and DC equivalent circuit diagrams.
2. Analysis of the current series negative feedback process and the impact of negative feedback on circuit parameters.
5. Common collector amplifier circuit (emitter follower)
![Common collector amplifier circuit (emitter follower)](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/1c1296acbb23e229c03d19b198afa607.png)
1. The role of components, the purpose of the circuit, voltage amplification factor, input and output signal voltage phase relationship, AC and DC equivalent circuit diagrams. Input and output impedance of circuit
Features.
6. Circuit feedback block diagram
![Circuit feedback block diagram](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/d21db1812fbbff44a22a7874039f27c3.png)
1. The concept of feedback, positive and negative feedback and their judgment methods, parallel feedback and series feedback and their judgment methods, current feedback and voltage feedback and their judgment methods.
2. Amplification gain with negative feedback circuit.
7. Diode voltage stabilizing circuit
![Diode voltage stabilizing circuit](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/064a5d952e0a60f495c75d8e8f7670c0.png)
8. Series regulated power supply
![, series regulated power supply](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/8b93d7500aa91702aafbcb1bb7b30d76.png)
9. Differential amplifier circuit
![Differential amplifier circuit](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/5a3d00ae0fce235e2b4387502874ec52.png)
10. Field effect tube amplifier circuit
![10. Field effect tube amplifier circuit](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/2b171d39305456f51fae4d167ca778e3.png)
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- How to read resistor color codes? Resistor color codes illustrated
- Causes and solutions for noise in digital Class D amplifiers
- Transfer characteristics of BJT, how to apply Shockley equation?
- How to calculate the value of capacitors in parallel?
- Causes of PCB deformation How to prevent circuit board bending and warping
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- LED lights that “drain” battery power
- FL52C4 induction electronic greeter
- As a qualified engineer, you need to remember these circuit diagrams throughout your life!
- Highly stable thermocouple temperature measurement amplifier circuit composed of OP07
- High input impedance buffer amplifier circuit
- Adopting negative feedback broadband amplifier circuit
- Radio high frequency amplifier circuit
- Three amplification circuits of junction field effect transistors - common source
- Differential voltage amplifier circuit
- Differential amplifier circuit
- Transformer coupled amplifier circuit
- Single tuned IF amplifier circuit for radio
