Wireless FM transmitter circuit diagram with a transmission distance of up to 3000 meters
Source: InternetPublisher:奥特man123 Keywords: Wireless circuit diagram FM transmitter circuit Updated: 2021/03/29
The working voltage is 9V and the working current is 2~6mA. The component parameters can be seen in the figure. BG1 is 9018 and BG2 is C1959 (it can also be 9018, but the power is smaller. If it is D-40, the shooting distance can be extended to 1000 meters. D -40 is difficult to buy in electronic stores.), L1 and L2 are 0.5mm enameled wire wound around 0.5 round rod 4 and 3 times, the working voltage can be increased to 12V, so the emission distance can be increased, but the frequency will change , the entire circuit is best powered by batteries to achieve the best results in sound quality and frequency stabilization. When debugging, first turn off BG2, adjust the frequency you need, and finally turn on the BG2 circuit to adjust the power. I used BG1--D40 and BG2--C1970 for this circuit and the effect is very good. The voltage is 12V, the working voltage of BG1 is 6V, and the distance is 3000 meters (directional experiment). If you want to use D-40, please note that the working voltage of D-40 is 6V! It is best to install this circuit in an iron box and add a fading reduction network to the input end.
- TA8164P FM Radio
- Design and production of satellite receiver crash recovery circuit
- Change the frequency of the campus radio
- RXM-921/916/903/868/433-ES Series Receiver Modules
- MCl3175/MCl3176 FM/AM 928~902 MHz/470~260 MHz Transmitter
- MICRFl03 ASK 1 GHz~800 MHz Transmitter
- XE1203 FSK 915/868/433 MHz Transceiver
- TR5100 FM 150~15 MHz transceiver
- MC33493/D OOK/FSK 928~902 MHz/434~315 MHz dual frequency transmitter
- AT86RF211 FSK 950~400 MHz transceiver
- Wireless transmitter circuit diagram
- Common double-tube energy-saving lamp circuit schematic diagram
- Pressure signal conditioning circuit circuit diagram based on MAX1450
- Voice controlled flash LED light circuit diagram
- Mobile phone production of remote home appliance remote control circuit diagram
- Unbalanced current drying motor winding circuit diagram
- Level display circuit diagram composed of LED level meter driver integrated circuit
- Wireless active subwoofer 01
- High performance wireless karaoke microphone circuit
- Long distance wireless coding alarm
