Hall integrated component AC motor on-off circuit diagram
Source: InternetPublisher:sigma Keywords: power outage circuit diagram ac motor Updated: 2021/07/15
As shown in the figure, it is an AC motor on -off circuit using Hall integrated components . This is a proximity switch where magnetic objects such as magnets approach the Hall integrated components to make the induction motor run. In the circuit, the UGN304OT uses a bidirectional thyristor VS in the output circuit, so that the AC induction motor can be directly switched on and off. In order to improve the withstand voltage and circuit structure requirements, the photocoupler TLP511GA is used to isolate low-voltage DC and high-voltage AC.
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- How do Zener diodes protect circuits?
- What is the difference between CPLD and FPGA?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Share an interesting LED decoration project
- How to install the accelerometer
- LED Night Light
- Circuit diagram of a differential amplifier circuit
- Circuit diagram of an example of differential and integral circuits
- As a qualified engineer, you need to remember these circuit diagrams throughout your life!
- Tube crossover balanced inverter circuit diagram
- 220V welding machine wiring circuit diagram
- Automatic periodic switching circuit 4
- Time controller circuit that turns on or off the power supply regularly
- Thyristor type overcurrent protection circuit 6
- Turn-off voltage waveform circuit of IGBT in hard-switching chopper circuit
- JSDJ type transistor power off delay relay circuit
- Wire breaking circuit
- Cable power outage tracer circuit
