Circuit diagram of boost converter with direct control of LED current
Source: InternetPublisher:难得正经 Keywords: Boost converter LED Updated: 2020/08/05
To control the current of the white LED , the current of the white LED must be detected. The simplest and most convenient way to detect the current of the white LED is to use a current sensing resistor in series with the white LED. In this way, the total output voltage required by the converter is white light. The sum of the LED forward voltage and the voltage drop of the current sensing resistor. In order to simplify the circuit and reduce costs, it is best to design the current-sense resistor so that the voltage drop across the resistor is the same as the feedback voltage of the selected converter. The voltage drop of the current-sense resistor should be as small as possible, so as to minimize power consumption. Too high a voltage will only increase power consumption. The sum of the forward voltage of the white LED and the voltage drop of the current sensing resistor is usually higher than the mobile phone battery voltage, so a boost converter must be used to provide power. Assuming that the feedback voltage of the converter is 500mV, the total output voltage must be between 4.1 and 4.3V. The boost converter with direct control of white LED current is shown in the figure.
- Example of LED AC drive circuit
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- Low cost LED automatic emergency light circuit
- Six LED stereo VU display circuit built with IC LM3915
- LED Signage with RS232 Port Operation Guide
- Colorimeter circuit
- One of the circuits that control one light in multiple placesb
- Chandelier brightness controller circuit using thyristor
- Shock resistant soft start constant current LED lighting circuit
- Bedside lamp controller circuit
- Do you know about the YTSwitch-6 LED driver IC with high efficiency and extremely low standby power?
- What sensors does the phone have?
- LED emergency light circuit diagram
- Driving circuit diagram of a low-power LED bulb
- "clairvoyance" charger circuit diagram
- 3W high power LED drive circuit diagram
- Level display circuit diagram composed of LED level meter driver integrated circuit
- Positive terminal buck/boost LED constant current drive circuit diagram
- Power outage sound and light alarm circuit
- Digital camera flash control circuit
