latch storage circuit
Source: InternetPublisher:笑流年 Keywords: WIDTH transformer Updated: 2020/07/22
The use of saturable transformers makes the memory less likely to be lost and not affected by erroneous command signals. The transformer remains magnetically biased without the need for a voltage supply to provide a baseline state, and when the power is turned on, the memory latch returns. When the bit is initially stored in the circuit , the set or reset pulse must have a minimum width of 35 microseconds and a minimum interval of 65 microseconds.
- What is the difference between MOSFET and BJT? Which one is better between MOSFET and BJT?
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- The Importance and Ideal Model of Impedance Matching
- Analysis of the working principle of CMOS/CCD image sensor
- What are the types of commonly used batteries?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Working principle/advantages/disadvantages/size of optical fiber
- Basic characteristics/working principles and application circuits of tunnel diodes
- Summary of knowledge points of multiplexer
- Touch circuit design and analysis
- LA4555 power amplifier circuit diagram
- LA4261 power amplifier circuit diagram
- HA1384 power amplifier circuit diagram
- AN7168 power amplifier circuit diagram
- AN7112 power amplifier circuit diagram
- Common double-tube energy-saving lamp circuit schematic diagram
- Automatic disconnect battery charger circuit diagram
- Nickel cadmium charger circuit diagram
- Circuit diagram for driving 4 white LEDs based on charge pump
- MAX16834 driver LED circuit diagram
