Negative voltage generation circuit diagram
Source: InternetPublisher:酷到被通缉 Keywords: Microcontroller power supply and other power circuits Updated: 2020/10/11
Needless to say, I need to explain the usefulness of positive voltage. In electronic circuits, we often need to use negative voltage. For example, when we use an op amp, we often need to establish a negative voltage for it. Let’s briefly talk about his circuit using a positive voltage of 5V to a negative voltage of 5V as an example.
Usually when I need to use negative voltage, I usually choose to use a dedicated negative voltage generating chip, but these chips are relatively expensive, such as ICL7600, LT1054, etc. Oh, I almost forgot about MC34063. This chip is used the most. I won’t mention the negative voltage generating circuit of 34063 here, it is in the datasheet. Let’s take a look at the two negative voltage generating circuits we commonly use in microcontroller electronic circuits.
![Negative voltage generation circuit diagram](http://www.eeworld.com.cn/circuit/upload/c1eb34b0b1662c6bc30bb6734443ad40/4831f75bce906785463ee7c99e1650bf.jpg)
Many of today's microcontrollers are equipped with PWM output. When we use microcontrollers, PWM is often not used. It is a good choice to use it to assist in generating negative pressure.
The above circuit is the simplest negative voltage generating circuit. The original components he uses are the least. We only need to provide him with a square wave of about 1kHz, which is quite simple. It should be noted here that the load generation capability of this circuit is very weak, and at the same time, the voltage drop is relatively large after adding a load.
Due to the above reasons, the following circuit was produced.
![Negative voltage generation circuit diagram](http://www.eeworld.com.cn/circuit/upload/c1eb34b0b1662c6bc30bb6734443ad40/70d9c20e8ebfa50e7b97453d2dbd53d5.jpg)
- Schematic diagram of car cigarette lighter to USB power port
- In-depth analysis of DC-AC converter inverter
- Using Lead-acid Battery as Power Source for Walkman
- Simple and practical LED lamp driving circuit
- LED Driver ZD1680
- Switching power supply circuit composition and function introduction of each part
- Principles and precautions of active discharge circuit
- CNC regulated power supply production
- Car power 1.5V-12V six-speed converter
- USB power socket using the car battery
- Design of temperature detection circuit implemented by single chip microcomputer
- Teach you a reliable new method to implement overvoltage protection for electronic signal inputs
- Vishay FRED Pt® ultra-fast recovery rectifier launched on the market
- Utilizing light sensing circuits to reduce photodiode bandwidth and noise effects
- About star-delta step-down start plc ladder diagram circuit diagram
- About the working principle of single touch mode light switch
- Minimum system interface circuit based on AT89C52 microcontroller
- Microcontroller measurement circuit
- IR2130 combined with microcontroller and SLE4520 for three-phase frequency conversion system diagram
- Interface between serial IO port AD converter and microcontroller
