Subsonic fan speed control remote control circuit diagram
Source: InternetPublisher:ohahaha Keywords: Circuit diagram speed regulation ultrasonic remote control circuit Updated: 2021/08/18
It can realize remote control switching and speed adjustment of electric fans , and can also realize remote control of other household switches. Its main feature is that the transmitter uses a sub-ultrasonic transmitter, which has no directional restrictions, requires no power supply, and is durable. The sub- ultrasonic signal received by the piezoelectric buzzer is amplified by V1, frequency selected by L and C4, and then amplified by V2 and outputs pulses. Every time you operate, pinch the transmitter, and the V2 collector will output a positive pulse trigger signal, which is counted by the decimal counter CD4017. Use the Q1, Q2 and Q3 gears of CD4017. When the fourth signal arrives, the IC is cleared. The IC controls the transistor to drive the relay. The contacts of the relay are connected to the speed regulating coil of the original speed regulator to change the speed of the electric fan. The circuit can be expanded to 9 channels with slight modifications.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Use your smartphone to turn on/off the power in your home
- Introduction to the internal structure of the Delta winding motor
- How to set up a cheap beam break sensor control distance scene using a reflector
- Squirrel cage asynchronous motor reverse braking control circuit
- Simple phase failure protection circuit composed of intermediate relay
- One-way rotation circuit of motor controlled by contactor
- Design and production of wireless multi-location control switch circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Electric vehicle battery charging protection circuit
- Flashing wall light control circuit
- Simple timing control circuit
- Digital camera flash control circuit
- PLC transmission line automatic reclosing control circuit
- Multi-pole leakage protector circuit a
- Photoelectric output control circuit
- Small power electric heater temperature detection control circuit
- Forward and reverse control circuit of micro DC motor a
- audio signal control circuit
- Apply LOGO! Electric gate control circuit b
