Constant current parallel voltage stabilized power supply circuit diagram composed of LM317
Source: InternetPublisher:张三叔 Keywords: Constant current regulated power supply circuit LM317 Updated: 2021/02/15
As shown in the figure is a constant current parallel regulated power supply. It has the characteristics of high speed, low noise and low internal resistance. Using LM317 as a constant current source, it can provide a constant current of 560mA to the load. The field effect transistor 2SR3D and the light emitting tube provide a low-noise reference voltage. LM741 (op amp) serves as an error amplifier to compare and amplify the reference voltage and sampling voltage. Two 3DD15 are used to adjust the output voltage to achieve stable output voltage.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- 220V Remote Load Monitor
- Basic circuit description of adjustable voltage regulator LM317
- LED rechargeable flashlight circuit diagram
- 3~15V 10A adjustable voltage regulated power supply
- Adjustable voltage power socket
- Design of electric vehicle charger
- Mc34063 MP3 Switching Charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- The module prohibits constant current and constant voltage function port wiring
- Differential circuit with constant current
- Production of high-quality active two-way constant current power amplifier 01
- DC servo constant current power amplifier 02
- Basic application circuit of LM31705
- Basic application circuit of LM31702
- General circuit diagram of a simple battery automatic constant current charging circuit
- MAX6969 chip 16-port 5.5V constant current LED driver circuit diagram
- Constant current amplifier circuit
- Multipurpose constant current automatic charger circuit diagram
