555 lantern electronic switch circuit diagram
Source: InternetPublisher:消失的歌 Keywords: Switch circuit diagram colored lights electronic switch Updated: 2020/03/11
The switching circuit is shown in the figure and consists of a step-down rectifier circuit, an oscillation circuit and an electronically controlled switching circuit.
IC 1 (555) and RP1, R1, C1 form an astable multivibrator. The oscillation period T=0.693 (RP1+2R1) C1, which is about 1 to 10 seconds, can be selected by adjusting RP1. The pulse wave output by IC 1 is integrated by RP2 and C2 and then added to VT1 to control the on and off of SCR, thereby controlling the lighting or extinguishing of the colored lights .
ck="window.open(this.src)" alt="Click to see larger image"/>
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- FPGA Features and Architecture
- How to calculate the value of capacitors in parallel?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Build a musical fountain using Arduino and sound sensor
- Structural diagram and function of sliding resistor
- Star finder battery indicator circuit
- LED Bicycle Lights
- SCR three-phase AC switch circuit diagram
- Static switch circuit diagram of integrated trigger tdal024
- Clever use of kd-28 as voice-activated switch circuit diagram
- Automatic cycle switch circuit diagram
- Sonic remote control switch circuit diagram
- Ultrasonic remote control switch circuit diagram
- Zero volt switch circuit diagram
- AC single pole double throw switch circuit diagram
- Multifunctional leakage protection switch circuit diagram
- Touch-type silicon controlled zero-crossing switch circuit diagram
