555 ultra-low frequency millivolt signal generator circuit diagram
Source: InternetPublisher:JFET Keywords: Signal generator generator circuit circuit diagram ultra low frequency Updated: 2020/06/09
The circuit is shown in the figure. The generator consists of an oscillator, voltage follower, amplitude zero adjustment, zero point migration circuit, etc. Used as a signal source for the automatic balance recorder operation test, the output signal is 0~50mV, the zero point shift of the output voltage is continuously adjustable by plus or minus 25mV, and the cycle rate is 30~40Hz.
IC1 (555) and VT1, VT2, R1, R2, and C form an astable multivibrator. VT1, R1, VT2, and R2 form charge and discharge constant current sources respectively. IC2 operational amplifier is used as a voltage follower, mainly used for impedance matching and low impedance output. The output voltage V0=V01-V02, by adjusting RP1 and RP2, the amplitude zero adjustment and level migration can be achieved.
- Signal diode arrays/configurations, freewheeling diode operation
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Working principle and truth table of JK flip-flop
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Analysis of three simple electronic dice circuits
- How does RCCB work?
- Make a flameless electronic candle using simple electronics and LEDs
- Experiment and production of NE555 time base integrated circuit
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- Do you know about the new RF vector signal generator?
- One-digit display timer circuit diagram
- Several improved sawtooth wave generator circuits - bootstrap circuit with voltage stabilization feedback
- Several improved sawtooth wave generator circuits-capacitive feedback circuit
- Voltage controlled sinusoidal oscillation signal generator circuit
- Voltage signal generator circuit with optical isolation
- Simple multifunctional signal generator circuit
- Digital high frequency signal generator
- Complementary ramp signal generator circuit diagram
- Multi-range multi-function signal generator circuit diagram composed of 5G8038
