Frequency selective photoelectric relay circuit diagram
Source: InternetPublisher:红水杯 Keywords: Optoelectronics circuit diagram relay circuit transistor Updated: 2020/12/26
This circuit controls a relay with the help of a modulated light signal. The modulation frequency is about 2.7kHz. The selectivity of the receiving circuit is determined by two parallel T-shaped networks (Figure b). The RC component parameters determine a very narrow cutoff band centered at 2.7kHz. For signals outside the frequency band, they are weakened by the strong negative feedback introduced from the emitter of the second transistor BC108 to the base of the first transistor BC108. Figure a shows the transmitter part of the circuit that controls the above circuit. It uses a gallium arsenide light-emitting diode CQY12B. Two transistors form a multivibrator with a resonant frequency of 2.7kHz and outputs a rectangular wave light pulse. The frequency can be accurately adjusted using a 250 ohm potentiometer.
ck="window.open(this.src)" alt="Click to see larger image" />
- How to use a microcontroller to control a servo motor?
- Introduction to the internal structure of the Delta winding motor
- How to set up a cheap beam break sensor control distance scene using a reflector
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Simple phase failure protection circuit composed of intermediate relay
- Add one more component to improve the phase failure protection function
- Design and analysis of voice control circuit
- Night dog barking anti-theft reminder circuit
- Car audio system anti-theft circuit
- Vibration anti-theft alarm circuit
- Laser flashlight circuit diagram
- Photoelectric remote control switch circuit
- Photoelectric pulse generating circuit
- Darkroom timed exposure circuit three
- One of the darkroom timed exposure circuits
- Photoelectric drive circuit
- GDK-1 type anti-exposure electric controller circuit
- Lightwave voice communication receiver circuit diagram
- Optoelectronic target shooting - gunshot and ball falling
- Ultrasonic remote control lighting circuit
