Photoelectric drive circuit
Source: InternetPublisher:王达业 Keywords: Optoelectronics drive circuit high voltage BSP Updated: 2020/11/02
Photoelectric drive circuit , the load in the picture is a strong circuit (2A) high voltage (AC 220 V) device, which can be
controlled by photoelectric conversion, which is safer and more reliable. The bidirectional thyristor is located in the AC high-voltage power supply circuit. As long as the tube
is turned on, 220 V AC high voltage will be added to the load. The control signal drives the light-emitting diode in the optocoupler through ICr, and controls IC2 through the
phototransistor in the optocoupler. The output of IC2 controls the trigger voltage of the thyristor, thereby controlling the load.
- This article will tell you the hard requirements of operational amplifiers
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Datasheet/Pinout/Technical Specifications of LMC555
- Working principle and truth table of JK flip-flop
- Working principle/advantages/disadvantages/size of optical fiber
- DIY a decorative lamp
- Share an interesting LED decoration project
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Share a Motorola amplifier circuit
- What is the difference between JFET and MOSFET
- Bone hyperplasia treatment circuit
- Homemade disinfectant circuit
- Physiotherapy ventilator circuit
- Egg warming circuit
- Peanut and melon seeds roasting machine circuit
- Crop anti-frost circuit
- Greenhouse temperature control circuit
- Biogas concentration detection line
- Audio function generator composed of ICL8038
- color discrimination circuit
