One of the darkroom timed exposure circuits
Source: InternetPublisher:明天见 Keywords: Optoelectronics BSP Updated: 2021/04/15
It emits an audible signal when the development time is approaching. This circuit can be used for photo development and amplification
timing, and can also be used in many other situations.
The given time link is composed of field effect transistor VTi, resistor, capacitor, etc., and
the sound signal link is composed of transistor VTz, transformer T, speaker B, etc.
When the potentiometer RP is adjusted to the resistance value of zero, the timer delay is 1 to 1.5 minutes; when the resistance value of the potentiometer RP is adjusted to the maximum,
the timer delay is 10 to 15 minutes. The tone of the audio signal depends on the capacity of the capacitor Cz, and the delay time depends on
the capacity of the capacitor Cl.
Turn on the switch s, the exposure starts (the exposure lamp circuit is not shown), and when it ends, the horn emits a sound signal. At this time, the power supply should
be cut off immediately to avoid wasting electric energy.
- Design and selection of electric control valve system drive
- Build a glove-controlled robotic arm
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to set up a cheap beam break sensor control distance scene using a reflector
- Motor self-starting circuit
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of a four-bit remote control component capable of remote reset
- Home wireless burglar alarm circuit
- Delay switch made with LM431
- Infrared detection alarm
- electromagnetic field sensor
- High-efficiency speaker circuit for rural stage
- Peanut and melon seeds roasting machine circuit
- Agricultural spraying and insecticide control circuit
- Frequency modulator composed of NE566
- Integrated synchronous detector composed of analog multiplier MC1596
- base amplitude modulation circuit
- ring amplitude modulation circuit
- Differential Amplifier Circuit
- common emitter amplifier circuit
