Lithium battery fast charger composed of LM3420
Source: InternetPublisher:念念Brown Keywords: Quick charger lithium battery Updated: 2020/07/27
This circuit uses the LM 3420-8.4 special lithium battery charger. The circuit is simple and has excellent performance. It can quickly charge two lithium batteries. When the charging voltage reaches the rated value (4.2V for a single lithium battery), the charging current drops to trickle charging to prevent permanent damage to the lithium battery caused by overvoltage charging.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- LED Driver ZD1680
- Voltage-current converter constructed with XTR110
- Car power 1.5V-12V six-speed converter
- 0.7~24V continuously adjustable current limiting power supply
- USB power socket using the car battery
- Converting a lithium battery charging board into a constant voltage and current charger
- Production of backup power supply for cordless phone
- Nickel-cadmium battery fast charger temperature control circuit
- 3v to 5v circuit diagram
- Three-way DC-DC converter circuit
- Single phase thyristor slotless nickel plated power circuit
- Warm current power supply circuit b
- Simple dual-channel variable DC power supply circuit
- Lithium battery fast charger composed of LM3420
- Pulse fast charger circuit
- Walkie-talkie fast charger circuit diagram
- Simple quick charger
