Flashlight single battery DCDC drive circuit diagram
Source: InternetPublisher:李商隐身 Keywords: DCDC single battery flashlight drive circuit diagram Updated: 2021/10/01
Simple and easy to make single -cell flashlight DC-DC drive circuit and fake battery.
According to the parameter voltage in the figure, when the voltage is 1.5V, the input current is 90mA, and the light-emitting tube current is more than 26mA. The magnetic ring was removed from the waste energy-saving lamp, and the diode 1N5819 could not be found and could be replaced by 1N4148. If you can't find a 47uF tantalum capacitor, you can also use a 25-47uF electrolytic capacitor instead, but the efficiency is slightly lower. Even so, the LED current is still 20mA. It is cost-effective to modify a small flashlight with a single battery.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Energy-saving motorcycle rectifier regulator
- Step-down power supply for driving relays
- ISO113 circuit that can reduce power consumption
- Simple and practical LED lamp driving circuit
- A novel and practical DC low voltage stabilized power supply
- 0.7~24V continuously adjustable current limiting power supply
- Constant current charger using light emitting diode as voltage regulator
- Mc34063 MP3 Switching Charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- 24V power supply pure flat display high voltage power supply circuit diagram
- Industrial product promotion and shopping guide DC power supply circuit
- 3v to 5v circuit diagram
- Single and multi-cell charging circuits
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Light control switch circuit controlled by flashlight 2
- CF1 (CF2) DC power supply circuit
- Remote control TV doorbell power circuit
- UCC3889 typical application circuit
