Automatic power-off nickel-cadmium battery charger circuit diagram
Source: InternetPublisher:elleny Keywords: Charger circuit diagram battery charger automatic power off nickel-cadmium battery Updated: 2021/01/01
This circuit uses a simple timer. When charging, four nickel-cadmium batteries with a capacity of 500mA each are connected in series. After the battery is charged with a constant current of 50mA for 15 hours, the circuit is automatically cut off and charging stops. The circuit uses 555 as the clock circuit, which generates a square wave with a period of 6 seconds to trigger IC2. IC2 is connected into an 8192:1 frequency divider. When charging, transistor T1 is turned on, causing relay RL1 to close, and the LED lights up to indicate that charging is in progress. After 555 sends the clock pulse from IC2 to 8192, pin 3 of IC2 becomes high potential, T1 is cut off, RL1 is released, and the circuit stops charging. When starting to charge, press switch S1 to cause the relay to automatically close and charge until the predetermined time.
- How about the boost converter TPS61299?
- A very convenient small power supply circuit to share
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Basic connection circuit of signal and power supply composed of ISOll3
- The constant current source composed of two transistors can drive high power
- Detailed explanation of 5v charger circuit diagram
- Switching power supply circuit composition and function introduction of each part
- Dual forward converter schematic diagram
- MIC4680 constant current charger
- Nickel-cadmium battery charger circuit diagram
- Low voltage DC power charger circuit diagram
- Lithium battery fast charger circuit diagram
- Solid electric fence charger circuit diagram
- Automatic charger circuit diagram
- Fully automatic charger circuit diagram
- Fast charger circuit diagram
- Multipurpose constant current automatic charger circuit diagram
- Charger circuit diagram using U2403B
