Voltage stabilization circuit diagram with adjustable output voltage
Source: InternetPublisher:MartinFowler Keywords: Circuit diagram voltage stabilizing circuit output voltage Updated: 2021/10/07
The resistance value of the R2+RP+R1 branch in the circuit determines the size of the current I. This current should be greater than the input current of the operational amplifier, which is approximately I=1mA. It is determined by the lowest value of the output voltage UAmin. Therefore, when adjusting to the highest output voltage value, the current I should also increase accordingly. The value of resistor R1 should be such that the voltage on R1 is greater than 0.5V under low output voltage to stabilize the operating range of the operational amplifier. The minimum output voltage is determined by UR1+UR, and the UR integrated voltage regulator is a constant voltage. The maximum output voltage is determined by UeX (-Us+UR2). If Us=1.5V, UR2=1V, then Umax≈Ue=-2.5V.
ck="window.open(this.src)" alt="Click to see larger image" />
- Analysis of the working principle of switching regulator
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Driving circuit of switching power supply field effect tube
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Transformerless AC-DC constant current LED driver circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Principles and precautions of active discharge circuit
- An ultra-low output voltage regulator
- Practical constant current charger-----Constant current charger
- LM317T voltage regulation adjustable circuit diagram explanation
- DC 12V to AC 100V inverter power supply circuit design
- Power supply circuit design optimized for digital light projectors
- 3v to 5v circuit diagram
- Power circuit with smoothing filter capacitor
- Timing switch AC power circuit
- Recording level power supply circuit
- Class A power amplifier power circuit
- DC power supply circuit for semiconductor radio
- AC-DC conversion power supply-inverter power supply circuit
- ±5V, ±12V power circuit B
