Current limiting high current voltage stabilizing circuit diagram
Source: InternetPublisher:风向西瓜 Keywords: Circuit diagram voltage stabilizing circuit Updated: 2020/02/23
The selection of resistors R1 and R2 in the figure must meet the condition of R2》5·R1. For example, R1=0.2 ohm, R2=1 ohm. The actual apparent current requires R1 to be between 0.1 and 2 ohms, and Ube=Ud has the relationship UR1=UR2, so I2 is about 5 times smaller than I3, the total current I1=I2+I3≈I4, ignoring the base current of the transistor, Then I3 is equivalent to the regulation current of the integrated circuit IC . For transistors with large current, resistor R3 can be selected between 10 and 20 ohms. For small current transistors, 100 ohms can be selected.
ck="window.open(this.src)" alt="Click to see larger image" />
- A very convenient small power supply circuit to share
- Schematic diagram of car cigarette lighter to USB power port
- Benefits of Wide Bandgap Technology for Power Converters
- Using Lead-acid Battery as Power Source for Walkman
- ISO113 circuit that can reduce power consumption
- Recommended circuits for different power on times of LM4911
- Visible laser digital control modulation driver
- Miniature polarity reversal power supply using MAX1721
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Circuit diagram explanation: simple switching power supply circuit diagram
- DC 12V to AC 100V inverter power supply circuit design
- Power supply circuit design optimized for digital light projectors
- Power circuit a composed of intelligent thyristor modules
- Laser power circuit
- Super Class A power amplifier power circuit
- led drive power circuit
- Music power circuit
- Common power circuits and applications 08
- Common power circuits and applications 05
- Inverter power circuit
