Delayed light off device principle circuit diagram
Source: InternetPublisher:公子李 Keywords: Circuit diagram delayed lights off Updated: 2020/08/07
As shown in the figure, the circuit working principle of the device is shown in the figure. When the button switch AN is not pressed, the transistor VT has no bias current and is cut off. At this time, the resistance between c--e of VT is greater than 50K, so the space between the ① and ② pins of LSE is equivalent to an open circuit, and the ④ pin of LSE outputs low level. , relay J is in the released state. When the switch AN is pressed, its current quickly charges the capacitor C3 through AN , and the charge is fully charged within 1 second. At this time, the transistor VT is turned on, and the resistance between its poles is reduced, so LSE is turned on, and its ④ pin outputs high level, relay J is energized and closed, and lamp H lights up. After releasing your hand, the charge in C3 is discharged to VT through resistor R, maintaining the conduction of VT. When the charge in C3 is discharged, VT is cut off, J is automatically released, and H goes out. The lighting time of the lamp H depends on the values of R and C3. According to the values shown in Figure *, the delay time after testing is approximately 1 minute and 30 seconds.
ck="window.open(this.src)" alt="Click to see larger image" />
- Example of LED AC drive circuit
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- Measurement and analysis of automatic emergency lighting circuit
- Six LED stereo VU display circuit built with IC LM3915
- Design and production of rain control and light control timing controller based on P87LPC764
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Musical doorbell without buttons
- Practical sensitive light-controlled switch circuit diagram
- Transistor storage time test circuit
- AC and DC dual-purpose flash light
- How to learn circuit diagrams?
- Common double-tube energy-saving lamp circuit schematic diagram
- 555 photo exposure timer circuit diagram
- Inspection circuit diagram for broken rotor bar of three-phase motor
- AC grid powered light emitting diode circuit diagram
- Three-color marquee circuit diagram
- Insulation resistance meter circuit diagram
- Touch lighting delayed light off circuit 3
- Lighting delay light off circuit using optocoupler b
- One of the lighting delay-off circuits using thyristors
