Bipolar stepper motor drive circuit diagram
Source: InternetPublisher:ghaytweyhtoo Keywords: Stepper motor drive motor drive circuit drive circuit diagram transistor Updated: 2020/04/06
The drive circuit of a bipolar stepper motor is shown in the figure. It uses eight transistors to drive two sets of phases. Bipolar drive circuits can drive four-wire or six-wire stepper motors at the same time. Although four-wire motors can only use bipolar drive circuits, it can significantly reduce the cost of mass production applications. The number of transistors in a bipolar stepper motor drive circuit is twice that of a unipolar drive circuit. The four lower-end transistors are usually directly driven by a microcontroller, and the upper-end transistors require a higher-cost upper-end drive circuit. The transistor of a bipolar drive circuit only needs to withstand the motor voltage, so it does not require a clamping circuit like a unipolar drive circuit.
ck="window.open(this.src)" alt="Click to see larger image" />
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to build a simple tachometer using an infrared reflectance sensor
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- A simple door handle touch alarm circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Audio interface protection circuit
- Electric vehicle battery charging protection circuit
- Design and production of no-load automatic power-off device for household power supply
- PIC microcontroller controlled remote anti-theft alarm circuit
- Agricultural spraying and insecticide control circuit
- Electronic rhythm control circuit
- Boiler control circuit
- Water dispenser double sheet control circuit
- Multi-pole leakage protector circuit a
- Automatic tuning control circuit
- Galanz rice cooker control circuit
- Range hood detection control circuit
- Temperature detection control circuit of electric kettle
- Temperature measurement and control circuit
