555 five-purpose three-state audio logic pen circuit diagram
Source: InternetPublisher:newrudeman Keywords: Audio circuit diagram WIDTH Updated: 2021/03/05
As shown, the controller includes buck rectifier, monostable and AC solid state relays. 555 and R2, RP1, C4, etc. form a monostable circuit. When AN is pressed , pin 3 of 555 is at high level, which turns on the AC output terminal of the AC solid-state relay, connects the load, and starts timing. The timing time, that is, the temporary stable time of the monostable state td=1.1RP1C4, the maximum timing of the parameters shown in the figure is about 30 minutes, which can be adjusted by adjusting RP1.
ck="window.open(this.src)" alt="Click to see larger image" />
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- What are the parts of the fpga design process
- How to calculate the value of capacitors in parallel?
- Diode-based clipping circuit
- Share an interesting LED decoration project
- Structural diagram and function of sliding resistor
- What types of force sensors are there?
- Make a simple AM radio with digital circuit
- Hardware circuit diagram of ultrasonic range finder
- LA4500 power amplifier circuit diagram
- Ringing switch start protection circuit diagram
- Crystal oscillator 80mW FM transmitter production circuit diagram
- Three-phase three-wire active energy meter direct connection type
- MAX1870A - Typical Operating Circuit
- Hall switch collector output interface circuit diagram
- Signal generator circuit diagram
- Simple signal generator for signal tracing
- Variable gain amplifier circuit
