NE555 pin diagram and ne555 circuit application
Source: InternetPublisher:小胖友 Keywords: 555 circuit NE555 pin diagram circuit application Updated: 2021/01/19
ne555 is an integrated circuit that is widely used and has great functions. It is a small-scale integrated circuit and is used in many electronic products. The function of ne555 is to use the internal timer to form a time base circuit and provide timing pulses to other circuits. The ne555 time base circuit has two packaging forms, one is a dip dual in-line 8-pin package, and the other is a sop-8 small (smd) package. Other ha17555, lm555 and ca555 are products produced by different companies. The internal structure and working principle are the same.
The internal structure of ne555 can be equivalent to 23 transistors, 17 resistors, and two diodes, which form a comparator, an RS flip-flop, and other groups of unit circuits. In particular, three higher-precision 5k resistors form a resistor. Voltage divider. Provides the reference voltage for the upper and lower comparators. So it is called 555.
ne555 is manufactured by cmos process.
The NE555 pin diagram is introduced as follows
1 Ground GND 2 Trigger 3 Output 4 Reset 5 Control voltage 6 Threshold (threshold) 7 Discharge 8 Power supply voltage Vcc
The application is very wide.
The following is a simple ne 555 circuit application
- The unidirectional conduction current of the diode, the diode and its common uses
- How are diodes made using semiconductors?
- An article explains the working principle of the Wheatstone bridge
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- Analysis of the basic principle of measuring resistance by bridge method
- How to read resistor color codes? Resistor color codes illustrated
- What are the types of commonly used batteries?
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- What types of force sensors are there?
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- "Hot cake" heater principle NE555 heater circuit diagram
- Negative voltage generator circuit, NE555 charge pump
- Low power timer circuit
- NE555 timing circuit using ±15V power supply
- Use NE555 to make voice-controlled music lanterns
- NE555 flashing light circuit diagram
- High-efficiency pulse width modulation regulated power supply circuit diagram composed of NE555
- Stable output DC and DC converter circuit diagram composed of NE555
- 11 types of multivibrator circuit diagrams composed of 555 circuit diagrams
- Automatic refrigerator protection circuit using 555 circuit
