Negative voltage generator circuit, NE555 charge pump
Source: InternetPublisher:赔钱虎 Keywords: 555 circuit ne555 charge pump negative voltage generator circuit Updated: 2021/10/09
Keywords: NE555, charge pump circuit diagram
For sensor circuits or operational amplifier circuits, dual positive and negative power supplies are often required. However, for equipment such as vehicles that only have a single power supply, it is necessary to obtain the negative power supply from a single positive power supply. There are many methods, but using commercially available DC- DC converters are more convenient.
However, for situations where only a negative power supply is required to provide a small current, a charge pump circuit composed of a timing IC555 can be used. Although the output voltage changes to a certain extent with the output current, the circuit is simple and low-cost.
The circuit is shown in Figure 1. In theory, it can provide a negative voltage output equal to the 555 power supply voltage. However, in fact, the negative voltage output value is slightly lower than the absolute value of the power supply voltage. The reason is that diodes D1 and D2 have a forward voltage drop VF of about 0.6V.
![Negative voltage generator circuit NE555 charge pump](http://www.eeworld.com.cn/circuit/upload/1a24951da50bd95a181c85a24d358480/034c36b6fa3eca64d2b8f9cd9031a892.jpg)
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Signal diode arrays/configurations, freewheeling diode operation
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- DIY a decorative lamp
- Share an interesting LED decoration project
- How to build a triangle wave generator using an op amp and discrete components
- Structural diagram and function of sliding resistor
- What is a Demultiplexer
- Summary of knowledge points of multiplexer
- An example of proportional integral circuit diagram
- 555 8-pin integrated circuit diagram
- 555 square wave oscillation circuit
- Make strobe light with NE555
- Use NE555 to make a two-button touch light switch (2)
- Single-button bistable electronic switch made using NE555
- Clever use of NE555 as long timer circuit diagram
- Applying 555 circuit to transform the control circuit of foot-operated spot welding machine
- Bipolar DC and DC voltage stabilizing converter circuit diagram composed of NE555
- High-efficiency pulse width modulation regulated power supply circuit diagram composed of NE555
- DC voltage polarity converter circuit diagram composed of NE555
