Low power timer circuit
Source: InternetPublisher:super_star Keywords: Low power consumption timer circuit NE555 Updated: 2020/02/15
Shown is a timing control circuit. This circuit uses NAND gate CD4011 and time base circuit NE555 to form a low-power timing
control circuit. In this circuit, an RS flip-flop composed of NAND gate CD4011 is used as an electronic switch. When Kl is closed and connected to the power supply,
the 100 kfl resistor and O.Ol yF capacitor make the YF2 input terminal in a low level state, that is, s=o, Rl of the RS flip-flop, then Q=o, and the YF1
output terminal is locked at low level. Level "0". Transistor 9013 is turned off. The monostable timer composed of NE555 does not work. At this time, the entire circuit
only has quiescent currents of 1-2 UA for YF1, YF2 and 9013. When K2 is pressed, a negative pulse is generated, causing YF1 to output high level and lock
. 9013 is turned on, NE555 is powered and begins to enter a temporary steady state. The @ pin of NE555 outputs high level, and relay J is closed. After a delay,
the temporary steady state ends, and NE555 returns to steady state. At this time, the output of pin ③ is low level and relay J is released. If you want the timer to work again, you should
cut off the power switch Kl, then close it, and then press K2. The contacts of the relay can be used to control other electrical components.
- A simple magnetic switch circuit sharing
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to build a simple tachometer using an infrared reflectance sensor
- Introduction to the internal structure of the Delta winding motor
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Motor control circuit for starting and running without phase loss
- Add one more component to improve the phase failure protection function
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of the principle of automatic power-off switch during power outage
- Password type motorcycle anti-theft device
- ne555 temperature regulation circuit diagram
- Ultra-low power consumption LCD liquid crystal display circuit module design circuit diagram
- Low power timer circuit
- Use NE555 to make push-button delay energy-saving lamps (2)
- Use NE555 to make a two-button touch light switch (1)
- Using NE555 to make an incandescent lamp life extension controller
- Clever use of NE555 as a cycle timer circuit with adjustable on-off time
- NE555 DC voltage monitor circuit diagram
- Control circuit using NE555 integrated circuit_1
- Charger circuit diagram using NE555
