Sanyo 80P switching power supply circuit diagram
Source: InternetPublisher:方世玉223 Keywords: Switching power supply circuit diagram winding C51 Updated: 2021/08/13
As shown in the figure is the Sanyo 80P switching power supply circuit. The movements using Sanyo 80P switching power supply include: Sanyo CTP-3515, CTP-3525, CYP3915, CTP6916, CTP6921, CTO3227, Kunlun S371, Shanghai Z651-1 and Kangyi color TV wait.
Oscillation circuit
The 300V voltage is added to the B pole of the switch Q504 through R518 and R519, and Q504 starts to conduct. Pins (9) and (10) of T501 are positive feedback windings . The polarity of the positive feedback voltage is (9) positive (10) negative. The positive feedback is formed through the B and E poles of Q504, R516, R515 and D509, making Q504 quickly saturation .
After Q504 is saturated, the primary winding current of T501 increases linearly. This linearly increased current produces an upper negative and lower positive sawtooth wave voltage drop on R514. This voltage drop is sent to the B pole of Q502 through R505 and C507, and the sawtooth wave voltage Superimposed on the 6.8V DC voltage of Q502B pole. When the B pole voltage of Q502 is lower than a certain value, Q502 is turned on, making the left end of C51 0 almost grounded, and the negative voltage on the right end of C510 makes Q504 cut off.
After Q504 is cut off, the polarity of the induced voltage in each winding of T501 is completely reversed, and the secondary winding turns on D510 and D511. After being filtered by C515 and C518, the current voltages of 12V and 111V are obtained.
The cutoff of Q504 is maintained by the (10) positive (9) negative feedback voltage generated by the (10) and (9) windings of T501 through D508 and C510. At the same time, C510 is charged, generating left positive and right negative voltages (about 4V) , at the same time, T501 level (7), (1) windings and C51 1, R517 and C506 produce free oscillation. After half a cycle, the polarity of the induced voltage of each winding in T501 flips again, and Q504 enters the saturation state again . This cycle forms an oscillation.
Voltage stabilization process
Q501 and peripheral components constitute a sampling voltage stabilizing circuit. Pins (11) and (12) of T501 are error voltage sampling windings . The voltage on C508 is 30V under normal conditions. Obviously, changes in the output voltage will be reflected on C508. Q501 The E pole is connected to the reference voltage , and the sampled voltage is divided by R506, VR501, and R507 and then sent to the B pole of Q501, thereby controlling the conduction degree of Q501, which also controls the potential of the B pole of Q502, thereby controlling the conduction of Q504. The length of the period also controls the output voltage. Adjusting VR501 can change the output voltage.
D506 is a protection tube. When the B-pole voltage of Q502 is greater than 9V, D506 breaks down and conducts, Q502 also conducts, and the switching tube Q504 stops oscillating.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Practical and convenient fax machine power supply control circuit
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- The constant current source composed of two transistors can drive high power
- A simple positive and negative power supply circuit
- Adjustable regulated power supply with current limiting protection
- Integrated regulated power supply with continuously adjustable output voltage
- USB power socket using the car battery
- 5V to 12V switching power supply circuit diagram designed using MAX761
- Bootstrap boost switching power supply circuit diagram
- Toshiba TA two-chip series switching power supply circuit diagram
- Use UC1825 to form a 50W, 1.5MHZ switching power supply circuit diagram
- Dual output flyback switching power supply circuit diagram
- Transformerless switching power supply circuit diagram
- 30W feedback transformer switching power supply circuit diagram
- Vertical mill (C512 vertical lathe modification) electrical schematic circuit
- Switching power supply circuit diagram
- Frequency controlled switching power supply circuit diagram
