SAA1064 serial I2C bus LED dynamic driver interface circuit diagram
Source: InternetPublisher:newlandmark Keywords: A10 I2C bus LED interface circuit diagram Updated: 2021/11/12
The picture shows the SA A10 64 serial I2C bus LED display driver integrated circuit dynamic driver interface circuit.
Since the dynamic scan display of SAA1064 relies on the on-chip multi-switch data latch to control the circuit in real time, the main device does not need to intervene. Therefore, the dynamic working mode can best utilize the functional potential of SAA1064 and is the most commonly used working mode. The bit numbers of the LEDs in the figure correspond to the sequence of segment selection data in the data operation format. CEXT is the clock oscillation capacitor, which ensures the working signal for dynamic driving. MX1 and MX2 are the common pole drive signal output terminals of the display. The timing waveforms of MX1 and MX2 during dynamic scanning are shown in the figure.
- Six LED stereo VU display circuit built with IC LM3915
- Blinking LED circuit diagram based on LDR and resistor
- Solar battery and charging circuit
- battery charging circuit
- Resistor value selection circuit
- Transistor storage time test circuit
- 4-digit incandescent lamp display circuit
- Large light emitting diode display circuit
- Fluorescent lamp dimming circuit composed of thyristors
- Small current anti-theft alarm circuit
- Application circuit diagram for driving 5 white LEDs
- LED emergency light circuit diagram
- LED driver circuit diagram powered by solar cells
- Driving circuit diagram of a low-power LED bulb
- High battery life LED circuit based on GEC8310
- Three-phase phase loss alarm light circuit
- SAA1064 serial I2C bus LED dynamic driver interface circuit diagram
- Use CXA1005P to assemble the stereo player circuit
- TEA1062 call circuit diagram
