Transceiver circuit diagram of single-channel power line communication
Source: InternetPublisher:司马缸砸光 Keywords: Transceiver circuit power line circuit diagram communication Updated: 2021/03/29
This circuit is a single-channel power line communication transceiver application circuit. It uses the mains 380V or 220V low-voltage power lines to transmit analog and digital signals for wired communication. Figure (a) is a single-channel power line carrier transmitting circuit, and its core component ICl is the audio phase-locked loop integrated circuit LM567; Figure (b) is a single-channel power line carrier receiving circuit.
- Transmitter Receiver Circuit for 80 Meter Amateur Radio
- TA7792 Medium Wave Radio Circuit Diagram
- Homemade modified machine with 4 LNB inputs and audio and video outputs
- Homemade wireless voice transmitter for telephone
- MAX23691/Q 2000-800 MHz Dual-Band Tri-Mode Transmitter
- SB-200BRX superheterodyne receiving circuit
- RXM-900-HP-II FM/FSK 928~902 MHz Receiver Module
- RX3310A Receiver Module
- Common RF receiving circuit design for toys (3 high-frequency parts)
- XE1203 FSK 915/868/433 MHz Transceiver
- Common double-tube energy-saving lamp circuit schematic diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Tube crossover balanced inverter circuit diagram
- Simple level conversion circuit diagram
- Dual output electronic ballast circuit diagram
- Vehicle network electronic control unit circuit diagram
- Comparator circuit diagram suitable for headphone detection
- LED level meter driver integrated circuit diagram
- Instantaneous water heater automatic constant temperature experimental circuit diagram
- An accurate current monitor circuit diagram
