How to judge whether the thyristor is good or bad by triggering circuit
Source: InternetPublisher:傻阿乐 Keywords: analog circuit flip-flop trigger circuit Updated: 2020/11/18
Bidirectional thyristors are widely used, but their electrical characteristics are very special. Sometimes it is difficult to accurately measure their quality with a multimeter. Now a simple trigger circuit is used to accurately judge the quality of the thyristor by turning on and off the light bulb. .
![How to judge whether the thyristor is good or bad by triggering circuit](http://www.eeworld.com.cn/circuit/upload/f073490e03cf734bc9b10e5aa35c5e34/ff930aab730a1c4bb53691477ebb1490.jpg)
Method description:
1. As shown in the figure, the 1st pin is T1 pin, the 2nd pin is T2 pin, and the 3rd pin is G pin. Use the 1K resistance range or diode range of the multimeter to measure: T1--T2 resistance value is infinite, T1--G resistance value Between 90--200Ω, the resistance of T2--G is infinite (no matter how the red and black test leads are swapped).
2. When the switch connected to pin 2 of the optocoupler is turned on, the light bulb does not light up. When the switch is turned on, the light bulb lights up. When the switch is turned off, the light bulb goes out. The thyristor is good.
3. When the switch connected to pin 2 of the optocoupler is turned on and the bulb lights up (even slightly), the thyristor is bad.
4. When the switch connected to pin 2 of the optocoupler is turned on, the light bulb does not light up. When the switch is turned on, the light bulb lights up. When the switch is turned off, the light bulb still lights up. The thyristor is bad.
- What is a photocoupler and how to select and use one?
- Types and structures/characteristics/functions/implementations of smart sensors
- Basic characteristics/working principles and application circuits of tunnel diodes
- Share an interesting LED decoration project
- Analysis of three simple electronic dice circuits
- What types of force sensors are there?
- Star finder battery indicator circuit
- Simple LED advertising light circuit
- An example of proportional integral circuit diagram
- Circuit diagram of a differential amplifier circuit
- Comprehensive understanding of the principles and applications of ESD protection structures in cmos circuits
- Analysis of the principles of Zener diode circuit and Zener diode voltage stabilization circuit
- Transistor circuit diagram explanation
- DC tube amplifier working in Class B
- The principle of D/A conversion using resistors
- Language filter circuit designed by LM387
- Bad books do not bind circuits
- Bistable flip-flop practical circuit c
- JK flip-flop circuit
- Static switch circuit diagram of integrated trigger tdal024
