Circuit based on charge pump driving 4 white LEDs
Source: InternetPublisher:蓝猫淘气 Keywords: Charge pump white LED WIDTH Updated: 2020/10/19
In this circuit , the white LED driver is an adaptive charge pump based on 1x voltage mode and 1.5x voltage mode. The input of the charge pump is connected to the VIN pin and the output is connected to the VOUT pin. The charge pump has two operating modes: open loop and closed loop. In open-loop mode, the voltage at VOUT is equal to the input voltage multiplied by the gain multiple. When the charge pump operates in closed-loop mode, the voltage at VOUT is adjusted to a constant voltage value (Vreg). An internal current source controls the current to each white LED in a common-anode configuration, and the peak drive current can be programmed through an external resistor (Rset ) .
- IR2153 emergency fluorescent lamp circuit diagram
- LED Flasher circuit using 2 transistors for LED switching
- Solar battery and charging circuit
- Electronic massage and acupuncture device circuit
- Use NE555 to make a touch self-extinguishing table lamp
- Electronic music dimming desk lamp circuit
- Microwave Doppler warning circuit
- Large light emitting diode display circuit
- Remote anti-theft alarm
- Four color light circuit
- LA4510 power amplifier circuit diagram
- LA4507 power amplifier circuit diagram
- LA4261 power amplifier circuit diagram
- Solar water heater water automatic control circuit diagram
- 8W audio amplifier integrated circuit
- MJE13005×2 electronic ballast circuit diagram
- Nickel-cadmium battery charger circuit diagram
- Magnetic induction transmitter circuit diagram
- Automatic telephone call recording circuit
- High energy efficiency, low cost, non-isolated 350mA/12V LED driver
