NCP1014 drives LED lighting circuit
Source: InternetPublisher:jikai233 Keywords: LED lighting lighting circuit NCP1014 Updated: 2020/09/17
NCP 1014 can be used to drive 1 to 8 high-power HB-LEDs. The device is a compact fixed-frequency pulse-width modulation (PWM) converter integrating a high-voltage power switch with internal current limiting function . Since the NCP1014 operates at a fixed frequency, the current cannot rise above a certain point. This point is determined by the input voltage and the primary inductance before the end of the switching cycle or on-time. Due to the on-time limitation, the input current will follow the waveform of the input voltage, thus providing a higher power factor.
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- Delayed gradual lighting with protection function
- Six LED stereo VU display circuit built with IC LM3915
- "OR" logic element configuration circuit
- One of the water full alarm circuits
- Telephone theft automatic notification device circuit diagram
- Three-way music lantern circuit
- Seven-way flashing light string circuit
- Shock resistant soft start constant current LED lighting circuit
- Fluorescent lamp dimming circuit composed of thyristors
- Rural vegetable greenhouse lighting circuit
- Light controlled night light lighting circuit
- night light lighting circuit
- Combination lamp lighting circuit
- Two incandescent lamps connected in series lighting circuit
- One light one switch lighting circuit
- Lighting circuit two-place control connection circuit
- Remote control receiver lighting circuit
- Receiver lighting circuit
- TV special lighting circuit
