Two incandescent lamps connected in series lighting circuit
Source: InternetPublisher:张三叔 Keywords: incandescent lamp series connection lighting circuit BSP Updated: 2021/09/01
The schematic diagram of the incandescent lamp circuit shown in the figure is a common lighting circuit for incandescent lamps, using a one-light-one-switch wiring method.
In the family building of the living area, two incandescent lamps EL1 and EL2 are used in series. According to the principle of series voltage division, the voltage of each incandescent lamp
is lloVl. Although each incandescent lamp is darker, it has a longer service life and is often used for corridor lights.
- Build a Bluetooth-controlled wireless scoreboard
- TEC laser diode driver circuit
- DCD-1240 multifunctional rechargeable lighting
- Low cost LED automatic emergency light circuit
- Practical sensitive light-controlled switch circuit diagram
- Colorimeter circuit
- Digital display multi-function thermometer circuit
- Automotive LED driver circuit diagram using LT3486
- Mains undervoltage and overvoltage alarm circuit 2
- Photoelectric adjustment circuit
- electromagnetic field sensor
- Agricultural temperature control circuit
- Agricultural small tractor lighting circuit
- Double detuned loop frequency discriminator circuit
- Frequency modulator composed of NE566
- base amplitude modulation circuit
- Capacitive feedback oscillator circuit
- Second-order active band-stop filter circuit
- Color display circuit
- Digital stopwatch display circuit
