Circuit using NCP3065/NCP3066 to drive LED
Source: InternetPublisher:zht24 Keywords: LED NCP3065 WIDTH Updated: 2020/06/14
ON Semiconductor's NCP3065 /NCP3066 is a multi-mode LED controller that integrates a 1.5A switch and can be set to buck, boost, inverter (buck-boost), single-ended primary inductance converter (SEPIC), etc. Various topologies. The input voltage range of NCP3065/NCP3066 is 3.0~40V, has a low feedback voltage of 235mV, and the operating frequency is adjustable, up to 250kHz. Other features of the NCP3065/NCP3066 include: cycle-by-cycle current limiting, no need for control loop compensation, ceramic output capacitors available, analog and digital PWM dimming capabilities, internal thermal shutdown when hysteresis occurs, etc. The circuit using NCP3065 / NCP 3066 to drive LED is shown in the figure.
- Build a Bluetooth-controlled wireless scoreboard
- Experiment on realizing photoelectric alarm using photosensitive devices
- USB powered portable light
- LED Signage with RS232 Port Operation Guide
- Driving circuit for driving light-emitting diodes by IR53HD420
- Simple electronic doorbell circuit
- Large light emitting diode display circuit
- Automotive LED driver circuit diagram using LT3486
- Seven-way flashing light string circuit
- Shock resistant soft start constant current LED lighting circuit
- Op amp driving LEDs
- LED backlight driver module design circuit
- NE555 typical application circuit diagram (2)
- LED signal amplification circuit diagram
- Three-color marquee circuit diagram
- Inpatient pager circuit
- Fish farming thermostatic control circuit
- Three-phase alternating current detection circuit
- DC regulated power supply status display circuit
- Coin guessing game circuit
