Light-controlled switch circuit diagram of photoresistor (LDR)
Source: InternetPublisher:宋元浩 Keywords: Light controlled switch photoresistor switch circuit diagram transistor Updated: 2021/01/11
As shown in the circuit in the figure, when there is incident light, the transistor connected to the photoresistor LDR in the circuit is turned on to high level or zero level. It is sufficient for the transistor amplification factor to be B>100, and the photoresistor resistance is between 100 and 100k ohms, corresponding to the conditions of light exposure and darkness respectively. If you want to control a larger power load, you should use a Darlington transistor . ck="window.open(this.src)" alt="Click to see larger image"/>
- Build a Bluetooth-controlled wireless scoreboard
- Digital level display (CD40147, CD4511)
- Blinking LED circuit diagram based on LDR and resistor
- Laser detection and indicating device system circuit design
- Gas flameout alarm circuit
- Desk lamp dimming soft switch circuit
- Chandelier brightness controller circuit using thyristor
- Two-way electronic music doorbell circuit
- Automotive LED driver circuit diagram using LT3486
- Photoelectric adjustment circuit
- Night warning light circuit composed of multiple resonators
- Photoelectric control switching circuit composed of photoresistor lamp elements
- Photoelectric control relay circuit
- Automatic light control lighting circuit 2
- Infrared light remote control switch circuit diagram
- Light ophthalmic light switch circuit (1)
- Light-controlled switch circuit using photosensitive diode
- Practical light control switch circuit
- Simple light control switch circuit
- Light control switch circuit diagram
