Night warning light circuit composed of multiple resonators
Source: InternetPublisher:已注销 Keywords: Resonator BSP photoresistor Updated: 2020/09/24
Shown is a night warning light circuit composed of a multivibrator. The circuit is mainly
composed of a photoresistor RG, a power supply circuit , a time base integrated circuit IC (NE555), a thyristor VT1 and related components.
After the circuit is powered on, the AC 220V voltage is first stepped down by cl, rectified by VD, and stabilized by VS1 and VS2, and then a DC
voltage of about 12V is output to power each component in the circuit.
When there is enough light, the photoresistor is in a low resistance state, the ④ pin of the integrated circuit LC is in a low level state, the lc does not work, and the warning light
EL does not light up.
When the light brightness decreases at night, the resistance value of the photoresistor becomes larger, the voltage of pin ④ of the IC increases, IC starts to work, and the
oscillator circuit composed of peripheral components starts to oscillate, so that pin ③ outputs an oscillation signal to drive the thyristor VT1. It turns on and off at a certain frequency, and the warning
light flashes.
- Audio level LED and digital dual display circuit
- "OR" logic element configuration circuit
- Simple electronic doorbell circuit
- Lighting audio control circuit
- Gift lamp music box circuit
- Motor speed photoelectric control circuit
- Chandelier brightness controller circuit using thyristor
- Large light emitting diode display circuit
- Shock resistant soft start constant current LED lighting circuit
- Four color light circuit
- Set timing circuit when power is on
- soil content measurement circuit
- Mixer built with analog multipliers
- Parallel crystal oscillator
- Double gate field effect transistor high frequency amplifier circuit
- OTL low frequency power amplifier circuit
- superheterodyne radio circuit
- color discrimination circuit
- Power phase sequence display circuit
- Sawtooth wave generator circuit (2)
