Battery discharge control indication circuit diagram
Source: InternetPublisher:公子李 Keywords: battery discharge circuit diagram contacts Updated: 2020/08/15
The figure below is the battery discharge control indication circuit. It consists of R1, RP, VDw, VT1 and J to form an over-discharge control circuit: R3, C2, VT2 and VT3 form an over-discharge indication circuit. When switch S is turned on, the battery voltage R1, RP The voltage breakdown VDw causes VT1 to saturate and conduct, the relay J works, the 1.3 normally open contact is connected, the green LED2 emits light, and the load R1 is powered to work. When the battery voltage drops to the originally set 10~10.5V, R1 and RP The partial voltage cannot breakdown VDw, so that VT1 cannot be saturated and conductive, and relay J stops working. The 1.3 normally open contact is disconnected, the 1.2 normally closed contact is connected, the green LED2 goes out, and the load R2 stops working. The battery voltage passes through R3 to charge C2 (the charging time is determined by R3 and C1), causing VT2 and VT3 to conduct intermittently. The red LED1 flashes to remind the user that the battery is under voltage at this time and the battery should be charged to avoid over-discharge of the battery. And damaged.
ck="window.open(this.src)" alt="Click to see larger image"/>
- A simple magnetic switch circuit sharing
- Tutorial on making your own remote-controlled robotic arm
- Build a glove-controlled robotic arm
- An automated model railroad layout project using a microcontroller
- Methods for Eliminating Noise of Brushed DC Motors
- Design and production of radio remote control fan stepless speed regulator
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and production of no-load automatic power-off device for household power supply
- Motorcycle anti-theft device circuit design
- Vibration anti-theft alarm circuit
- Photocell amplification control circuit
- Microwave oven control circuit
- Photoelectric detection output control circuit
- Microwave heating component control circuit schematic diagram
- Electric heater temperature detection control circuit
- Micro DC motor steady speed control circuit b
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- 35W half-wave resistor-capacitor phase-shift trigger actuation control circuit
- Apply LOGO! Electric gate control circuit b
