DC/DC conversion circuit diagram without isolation
Source: InternetPublisher:笑流年 Keywords: conversion circuit circuit diagram DC Updated: 2020/03/31
For a converter circuit that does not need to be isolated from the input and output voltages but only uses a working switch and L, D, and C, the most basic forms are as follows: Buck Converter (Buck Converter ), Boost Converter Converter (BoostConverter) and buck/boost converter (Buck-Boost Converter). The circuit principle is shown in the figure.
ck="window.open(this.src)" alt="Click to see larger image"/>
1. Buck converter
As shown in Figure (a) 9, in order to reduce the output ripple, an inductor L and a capacitor C are connected to the output end. VD in the figure is the freewheeling diode. The average value of the buck converter output voltage Vo is always less than the input voltage Vin. Whether the current iL in the inductor is continuous depends on the switching frequency, the parameter values of the filter inductor L and the capacitor C.
When the operating frequency of the circuit is high, if the inductance value of the inductor and the capacitance of the capacitor are large enough and they are ideal components, the output voltage can be considered to be constant after the circuit enters a steady state. When the transistor VT is turned on, the current in the inductor rises linearly; when the transistor VT is turned off, the current in the inductor cannot change suddenly, and the induced electromotive force on it causes the diode to turn on. In the steady state, the inductor filter maintains the DC component and eliminates the harmonic components, so the average output current is Io=Vo/RL;, where RL is the resistance of the load resistor.
2. Boost converter
Figure (b) shows a boost converter, which consists of a power transistor VT, an energy storage inductor L, a diode VD and a filter capacitor C. When the transistor VT is turned on, the power supply stores energy in the inductor, the inductor current increases, the polarity of the induced electromotive force is left positive and right negative, and the load capacitor C supplies power. When VT stops, the inductor current decreases, the polarity of the induced electromotive force is negative on the left and positive on the right. The inductor releases energy, supplies power to the load through the diode VD together with the input voltage, and charges the capacitor C at the same time. This converts low-voltage direct current into high-voltage direct current.
3. Buck/boost converter
Figure (c) shows a buck/boost converter. The average value of the output voltage Vo is greater than or less than the input voltage Vin, and their polarities are opposite.
- How about the boost converter TPS61299?
- How to Make a Soft Latch Circuit
- Energy-saving motorcycle rectifier regulator
- Step-down power supply for driving relays
- Simple and practical LED lamp driving circuit
- How to use SBR to improve power conversion efficiency
- Miniature polarity reversal power supply using MAX1721
- Dual forward converter schematic diagram
- Power supply circuit that can reduce LM317 ripple
- Integrated regulated power supply with continuously adjustable output voltage
- DC servo isolation amplifier with low input frequency band from DC to 100kHz
- Voltage-current conversion circuit
- Pulse conversion circuit
- DC field effect power amplifier circuit using AP500A
- LM3578A is used as a +5V, -15V DC, DC converter circuit diagram
- Multi-output DC and DC converter circuit diagram composed of L4970A
- Low-cost DC and DC converter circuit diagram composed of LT1307
- Simple positive polarity DC, DC converter circuit diagram
- Positive polarity DC, DC converter circuit diagram
- GDC-1 photoelectric speed sensor circuit
