Three-phase passive inverter circuit diagram
Source: InternetPublisher:无人共我 Keywords: Passive circuit diagram inverter circuit electronic switch Updated: 2021/04/08
The main circuit of the three- phase passive inverter circuit is shown in the figure. A three-phase bridge is composed of 6 unidirectional electronic switches , and each bridge arm is connected in parallel with a diode for freewheeling.
The power supply in the figure is marked with a box. In application, the DC power supply may be a voltage source or a current source. The output characteristics of the inverter are different depending on the power supply used. The opening sequence of the electronic switch is as follows: 1→2→3→4→5→6→1 in the figure. Make the three-phase load voltage a symmetrical three-phase alternating current.
Electronic switches can use fully controlled power electronic devices like single-phase bridge circuits, such as GTR, IGBT, GTO, etc. However, because the power of three-phase bridge inverter circuits is generally relatively large, ordinary thyristors are also used with certain commutation auxiliary circuits to realize the switching function. The capacity of fully controlled devices in sub-type circuits has not yet been increased to meet the needs of larger The requirements for power inverter circuits are relatively common. Now with the development of fully controlled device production technology, generally medium and small inverter circuits use fully controlled devices as electronic switches . However, the thyristors and auxiliary commutation circuits produced in the past A considerable number of inverters are still used in production equipment.
ck="window.open(this.src)" alt="Click to see larger image"/>
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- The constant current source composed of two transistors can drive high power
- Integrated regulated power supply with continuously adjustable output voltage
- CNC regulated power supply production
- Converting a lithium battery charging board into a constant voltage and current charger
- Mc34063 MP3 Switching Charger
- LM317T voltage regulation adjustable circuit diagram explanation
- Detailed explanation of mobile phone charger circuit diagram
- Power circuit a composed of intelligent thyristor modules
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Transistor stabilized current power supply circuit 2
- Class A power amplifier power circuit
- Single-button bistable electronic switch made using NE555
- Household emergency power circuit 02
- Wide input 350mA LED driver circuit based on NCL30000
- Touch electronic switch circuit diagram
- Multipurpose AC electronic switch circuit
