Old-fashioned electric shavers converted into rechargeable ones
Source: InternetPublisher:国民男神经 Keywords: Rechargeable linear voltage regulator electric shaver Updated: 2021/02/19
The old-fashioned electric shaver refers to the kind of electric shaver that only has a single-head circular blade cover and is powered by a battery. The actual shaving effect of this type of razor is very good, so it is still available on the market. It’s just that the AA battery used in this machine needs to be replaced frequently.
According to the characteristics of the original No. 1 battery of this machine and the large battery compartment space, the original shaver was transformed into a rechargeable electric shaver by modifying a No. 5 rechargeable battery and adding a simple charging circuit. Shaver: It is easy to use and saves the expense of regular batteries.
During modification, the required additional components and their circuit composition are as shown in the attached figure. Because the circuit is very simple, the components used can be connected by lap welding. For reliability, the battery and the overlapping circuit part should be fixed in the original battery compartment of the shaver with hot melt glue. In addition, the only minor changes to the original shaver are the openings to install the power input socket CZ and the IED charging indicator tube on the casing.
![The old-fashioned electric shaver is changed to a rechargeable Electric shaver power supply](http://www.eeworld.com.cn/circuit/upload/1a24951da50bd95a181c85a24d358480/b2ee784e744d75b37cf400ebdc1889df.jpg)
First of all, the external power supply here is an easily available mobile phone charger (i.e. AC220V/DC5V small power converter). The small output co-core plug on it also needs to be an ordinary small co-core power supply that can be plugged into it. Use a socket: This socket is the same as the external power socket used on many walkmans and pocket radios, and is easily available. When installing this socket, you only need to open a small square opening at the bottom of the shaver to expose the front end of the socket (the front of this type of socket has a square structure, which is stronger and will not loosen), install the socket, and apply heat to the back. The melt glue sticks firmly. Installing the LED charging indicator is even simpler. If you use a φ3mm LED light-emitting tube (red), you only need to select a suitable position on the shaver casing, drill a hole with a φ3mm drill bit, and embed the LED tube from the inside of the casing outward. hole, and then apply glue on the back to reinforce it (to prevent loosening).
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Schematic diagram of car cigarette lighter to USB power port
- In-depth analysis of DC-AC converter inverter
- Fabrication of multi-cell lithium battery charging circuit
- Boost drive circuit composed of RT8450
- A small and easy-to-make fast charger
- Design of electric vehicle charger
- Adjustable voltage regulated power supply circuit
- Practical constant current charger-----Constant current charger
- Homemade Electric Bike Fast Charger
- DC 12V to AC 100V inverter power supply circuit design
- Portable device charging power circuit design
- Dual adjustable power circuit
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- Warm current power circuit a
- Recording level power supply circuit
- Common power circuits and applications 05
- Common power circuits and applications 02
- SF-310B rechargeable electric shaver circuit diagram
