Color changing flash light principle circuit diagram
Source: InternetPublisher:风向西瓜 Keywords: Transistor oscillator power display power supply Updated: 2021/01/07
The collectors of the two transistors of the multivibrator are connected to light-emitting tubes respectively, and the light-emitting tubes can flash alternately according to the period of the multivibrator. This circuit has a wide range of uses and can be used for home decoration, etc.!
How the circuit works
This circuit uses high-gain pnp type germanium tubes vt3 and vt4 to form a multivibrator. There are two stages of inverters connected end to end. Capacitors c3 and c4 are used to couple the stages. Its working period is 1s!
Component selection and debugging
The transistor should choose 9012 or 9015 with a collector current greater than 50ma, and the light-emitting tube should choose a tube with high brightness!
If you want to change the flashing speed, you can adjust the capacity of c3 and c4, or you can use fine adjustment to replace r3 and r4. After the strips are set, replace them with the corresponding resistors!
![Color changing flash light principle circuit diagram](http://www.eeworld.com.cn/circuit/upload/2206f8a614272ca5fddaf41338f15167/1e1e847c894724ab41e87472cb44c497.jpg)
- Practical and convenient fax machine power supply control circuit
- What kind of circuit is a voltage regulator circuit?
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Recommended circuits for different power on times of LM4911
- Op amp power supply decoupling bypass measures
- Integrated regulated power supply with continuously adjustable output voltage
- Design of electric vehicle charger
- Car Audio Power Supply
- A low-cost, high-reliability battery charger for electric vehicles
- Detailed explanation of mobile phone charger circuit diagram
- Transistor circuit diagram explanation
- 3V-5V level conversion circuit diagram
- Old 20W electronic ballast circuit diagram
- One of the rechargeable time relay circuits
- A single-section transistor performance test circuit
- One of the soft-start regulated power supply circuits
- One of the anti-theft alarm circuits with warning wires
- Gas-sensitive alarm circuit 4
- One of the boiling water alarm circuits
- Simple buzzer circuit 4a
