Radio detection circuit diagram
Source: InternetPublisher:三月小雨 Keywords: Wireless communication radio detection circuit diagram Updated: 2020/05/28
It's just a radio detection circuit that detects the radio wave signal of the corresponding frequency and uses IC1 to determine the frequency and then triggers IC2 to broadcast the corresponding sound.
Y1 is a pyroelectric infrared sensor. The power supply provides a stable operating voltage to Y1 through R1, C2, and C3. C4 filters out high-frequency noise. The signal output by Y1 (if there is someone or animal activity in front of the sensor) is sent to pin 14 of IC1 through R7. . The circuit composed of IC1 and peripheral resistors and capacitors amplifies, shapes, and delays the signal. It outputs a pulse signal from pin 2 and triggers the music storage chip IC2 through R13. The dog barking signal output by IC2 passes through R15, VT1, and VT2. Amplify, drive speaker BL to produce sound, and inductor coil L1 plays the role of impedance matching.
- How to Build a Simple FM Radio Receiver on a Breadboard
- How to use CAN protocol in Arduino
- TA8164P FM Radio
- Convenient and practical electric guitar wireless transmitter
- MAX2360/MAX2362/MAX2364 I/Q 2000~1700 MHz/1000~800 MHz dual-band
- MICRFl04 ASK 470~300 MHz Transmitter
- DKl000R OOK 315 MHz Receiver Module
- RF2909 GMSK/QPSK/DQPSK/QAM 915 MHz Transmitter
- TXl00 ASK 1 GHz~100 MHz transmitter module
- T5761/T5760 ASK/FSK 870~868 MHz/928~902 MHz Receiver
- Wireless transmitter circuit diagram
- Design of wireless transmitting and receiving circuit based on Bluetooth
- DIY a simple FM wireless microphone
- BA1404 FM transmitter chip internal principle block diagram and application circuit diagram
- Circuit diagram of two wireless microphones made by 3DG12
- Frequency modulation (fm) waveform generator circuit diagram
- TEA1062 call circuit diagram
- Infrared communication circuit diagram based on microcontroller
- USB communication circuit
- CAN bus communication circuit
