Internal structure of DTL inverter circuit
Source: InternetPublisher:天天都吃好吃的 Keywords: transistor diode Updated: 2021/02/13
Shown is the internal structure of the DTL inverter circuit (M5936P). Diodes are used at the input , transistors are used for signal processing , and
the power supply is +5V. When the input terminal A is high level (digital "I"), the diode VDI is turned off, the transistor VTI is turned on, and the transistor VT2
is turned on and the output is low level (digital "O"). When the input is low level (digital "0"), the diode VD1 is turned on, the transistor VT1 is turned off,
the transistor VT2 is turned off, and the output is high level (digital "1").
- Analysis of the flow direction of transistor current
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- How does a series arrangement of Zener diodes affect the electrical behavior?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- How to read resistor color codes? Resistor color codes illustrated
- DIY a decorative lamp
- What is the difference between JFET and MOSFET
- What is a Demultiplexer
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- An example of proportional integral circuit diagram
- What is the fantasy world of diodes like?
- AC voltmeter
- Diode Balanced Mixer Circuit
- Proportional frequency discriminator circuit
- FM modulator strong-weak signal switching circuit c
- Improved multivibrator circuit c
- Internal structure of MC1411 series Darlington current driver d
- One of the non-contact proximity switch circuits
- Manual temperature control circuit 5
- Automatic water supply control circuit 2 for simultaneous monitoring of water tower and reservoir
