TA8200AH power amplifier circuit drawing schematic diagram
Source: InternetPublisher:张小哥 Keywords: Power DC/DC Updated: 2021/10/26
TA8200AH power amplifier circuit diagram schematic diagram.
TA8200AH power amplifier application circuit diagram
Maximum working power supply voltage 37V, output power 2×13W
Typical working power supply voltage 28V Normal working voltage 10-37V
Noise output noise
Icoo TYP typical quiescent current
Icoo MAX maximum quiescent current
RL load resistance
PO output power
RIN input resistance
TDH harmonic distortion
Normal working voltage means that it can work normally within this range.
Many parameters given by integrated circuits are tested according to typical operating voltages.
Pin connection: OTL
![TA8200AH power amplifier circuit drawing schematic diagram](http://www.eeworld.com.cn/circuit/upload/dd404e575050b4f77f424ee004959ae0/78e7cb26f5e32116865368661eb0efac.jpg)
- How about the boost converter TPS61299?
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Principles and precautions of active discharge circuit
- Dual forward converter schematic diagram
- Power supply circuit that can reduce LM317 ripple
- Homemade low-power UPS
- MIC4680 constant current charger
- Car Audio Power Supply
- DC output DC converter circuit
- Circuit diagram for using an ordinary TV remote control to control switches of other home appliances such as light bulbs and fans
- Ten circuit designs for precision full-wave rectification
- A typical application circuit diagram of PS61040
- STR5412 power circuit
- Uninterruptible power supply circuit diagram composed of MIC5158
- Power circuit a composed of intelligent thyristor modules
- Commonly used power circuits in printers
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
