Blood pressure sensing circuit diagram of BP01 pressure sensor
Source: InternetPublisher:赔钱虎 Keywords: Sensor power supply DC/DC Updated: 2021/09/23
As shown in the figure below, this circuit uses a BP01 pressure sensor and an operational amplifier MAX4472. The BP01 pressure sensor is specially designed to detect blood pressure and is mainly used for portable electronic blood pressure monitors. It uses a precision thick-film ceramic chip and nylon plastic package, which has the characteristics of high linearity, low noise and small external stress; it adopts internal calibration and temperature compensation methods to improve measurement accuracy, stability and repeatability. Within the full range, The accuracy is ±1%, and the zero-point offset is not greater than ±300μV. MAX4472 is a low-power amplifier chip from MAXIM that integrates four operational amplifiers. In this system, the internally integrated operational amplifier A is connected to a constant current source to provide a constant current for the pressure sensor. The operational amplifier B, operational amplifier C, and operational amplifier D form a differential input and single-ended output amplifier circuit, and are directly input to ADC0 to monitor the DC component of blood pressure.
![Blood pressure sensing circuit diagram of BP01 pressure sensor](http://www.eeworld.com.cn/circuit/upload/36febb367857f679db2a5b53b53271dd/dc704fd378cb45716c14a0c9695c909e.jpg)
- Using Lead-acid Battery as Power Source for Walkman
- Switching power supply circuit composition and function introduction of each part
- LNK304 non-isolated LED light string driver circuit
- Current/voltage conversion circuit using current converter
- Voltage-current converter constructed with XTR110
- Adjustable regulated power supply with current limiting protection
- An ultra-low output voltage regulator
- Adjustable voltage power socket
- Adjustable voltage regulated power supply circuit
- Homemade Electric Bike Fast Charger
- Overview of new multi-channel spectral sensors
- Circuit analysis of sensor and interface technology in ESP
- Baby bedwetting voice alarm circuit
- Color sensor amplification circuit
- Photo machine automatic exposure drive circuit
- One of the inductive anti-theft alarm circuits using RD627 sensor
- Sensor adjustment circuit diagram
- Sensor equivalent circuit diagram
- Sensor amplification circuit diagram
- Linear transform position sensor (LVDT) position measurement circuit
