High battery life LED circuit based on GEC8310
Source: InternetPublisher:桂花蒸 Keywords: power display power supply Updated: 2021/01/13
In order to improve efficiency and maximize battery life, the driving current of the LED is pulse current, and the rectifier circuit is removed. The so-called pulse current is because there is no output capacitor, and the LED only has driving current when the switch tube is turned off, and does not work when the switch tube is turned on. Since the inductor current is completely used to drive the LED, the peak current of the inductor is relatively small at this time. High battery life LED circuit based on GEC8310:
- Build a simple buck-boost regulator and test it on a breadboard
- In-depth analysis of DC-AC converter inverter
- Basic circuit description of adjustable voltage regulator LM317
- Visible laser digital control modulation driver
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Parallel DC regulated power supply circuit diagram
- An ultra-low output voltage regulator
- Homemade low-power UPS
- Electric bicycle battery charger circuit
- MIC4680 constant current charger
- LT3755 driver LED application circuit diagram
- Driving circuit diagram of a low-power LED bulb
- LED backlight driver module design circuit
- LED light column drive circuit
- A design method for electronic mosquito killing circuit
- Dual tone telephone dialing display circuit diagram
- Portable device charging power circuit design
- Laser power circuit
- Commonly used power circuits in printers
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
