Ultra-low quiescent current ZXSC100 application circuit analysis
Source: InternetPublisher:柯南道尔 Keywords: switching power supply quiescent current zxsc100 power switch tube Updated: 2021/07/28
![Ultra-low quiescent current ZXSC100 application circuit analysis](http://www.eeworld.com.cn/circuit/upload/b6d057d6e185e9816a0d1c1d73b3912e/c7da43fc194c3b691eb248aa69c4b9ea.jpg)
1. Input filter capacitor, used to stabilize the power supply voltage of the IC and filter out interference signals;
2. Connect to the emitter of the internal drive tube, and connect it to the drive current detection pin RE in low-power applications. If it does not connect to the RE pin in high-power applications;
3. Output voltage boost inductor;
4. Output voltage-boosting power switch tube;
5. Output boost voltage power switch tube working current detection resistor;
6. Output voltage boost diode;
7. RC frequency compensation circuit, used to stabilize the work of the circuit;
8. Output sampling resistor to stabilize the output voltage at the output voltage determined by the internal reference stable voltage;
9. Output filter capacitor to stabilize the output voltage and reduce the ripple voltage added to the load.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Schematic diagram of car cigarette lighter to USB power port
- Energy-saving motorcycle rectifier regulator
- Driving circuit that controls LED brightness using PWM signal
- Using CW34603 to form a circuit to change the polarity of the output power supply
- LM317 regulated power supply
- USB power socket using the car battery
- MIC4680 constant current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- LM317T voltage regulation adjustable circuit diagram explanation
- How should the power supply be decoupled?
- What is the difference between linear and switching power supplies?
- Do you understand military switching power supply reliability technology?
- Some brief summaries on power MOSFET applications, you deserve them
- Switching power supply genuine and fake load inspection
- LED drive circuit based on switching power supply
- The basic structure of a typical dot matrix printer switching power supply
- DNC-X50E special switching power supply
- Switching power supply high voltage constant current source circuit diagram
- Basic circuit diagram of switching power supply AC input and rectification and filtering
