LT3976 step-down switching regulator circuit
Source: InternetPublisher:newlandmark Keywords: Power switch voltage regulator Updated: 2021/10/03
The LT3976 is an adjustable frequency, monolithic, step-down switching regulator that accepts a wide input voltage range up to 40V. The low quiescent current design consumes only 3.3μA of supply current during no-load regulation. Low ripple burst mode operation (Burst Mode) can maintain high efficiency under low output current conditions while keeping the output ripple below 15mV in typical applications. As shown in the figure below, it is an adjustable frequency, monolithic , step-down type, accepts a wide input voltage range up to 40V LT3976 switching regulator circuit diagram.
- The basic principles of power supply design. What are the key components of a power supply?
- How about the boost converter TPS61299?
- Fabrication of multi-cell lithium battery charging circuit
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Op amp power supply decoupling bypass measures
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LNK304 non-isolated LED light string driver circuit
- MIC4680 constant current charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- A low-cost, high-reliability battery charger for electric vehicles
- STR5412 power circuit
- Power circuit of STR5412
- Industrial X-ray flaw detector delay control switch circuit diagram
- Fixed and switching hybrid regulated power supply electronic circuit diagram
- Schematic diagram of a sound and light dual control energy-saving switch circuit
- DC 12V to AC 100V inverter power supply circuit design
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Class A power amplifier power circuit
- Antenna amplifier synchronous power supply circuit
