Schematic diagram of a sound and light dual control energy-saving switch circuit
Source: InternetPublisher:qoistoochee128 Keywords: Power switch voltage regulator Updated: 2020/05/06
This circuit introduces an energy-saving switch with dual control of sound and light. During the day, the optical fiber is strong, and the photosensitive tube D is turned on by the light. At this time, regardless of whether there is sound triggering or not, pin 1 of the IC is low level, and passes through c, d, and e. , after f is applied, pin 8 is low level, the thyristor is cut off, and the bulb does not light up; at night, the photosensitive tube D is high resistance, and the level comparator exits the forced reset state. At this time, if there is a sound that triggers HTD, after amplification and shaping, the level of pin 1 is higher than the threshold level, the circuit flips, and C3 is charged, so that pin 5 can maintain a high level for tens of seconds after the sound disappears. , pin 8 is at a high level, triggering the thyristor to conduct, and the bulb lights up.
- How to Make a Soft Latch Circuit
- Benefits of Wide Bandgap Technology for Power Converters
- 220V Remote Load Monitor
- Driving circuit of switching power supply field effect tube
- ISO113 circuit that can reduce power consumption
- Dual forward converter schematic diagram
- Charging control circuit made by solar energy
- A novel and practical DC low voltage stabilized power supply
- Mc34063 MP3 Switching Charger
- Homemade Electric Bike Fast Charger
- STR5412 power circuit
- Power circuit of STR5412
- Industrial X-ray flaw detector delay control switch circuit diagram
- Fixed and switching hybrid regulated power supply electronic circuit diagram
- Schematic diagram of a sound and light dual control energy-saving switch circuit
- DC 12V to AC 100V inverter power supply circuit design
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Class A power amplifier power circuit
- Antenna amplifier synchronous power supply circuit
