Voltage stabilization circuit diagram with synchronous adjustment of positive and negative voltages
Source: InternetPublisher:刘德华河北分华 Keywords: Power switch voltage regulator Updated: 2020/03/14
In order to synchronize the positive and negative voltage adjustment, there should be R1=R2 in this circuit. The actual value is 4.4~22KΩ (1~0.5%). The value of R3 is R3=0.5R2. When the potentiometer resistance value is 10~25KΩ, the current limiting resistor R4 is 1.8KΩ. When the voltage regulation value of the integrated voltage stabilizing circuit is 5V, the output low voltage of the circuit is also 5V. The maximum output voltage is equivalent to UE-2V, so it is related to the allowed input voltage of the integrated circuit.
![Voltage stabilization circuit diagram with synchronous adjustment of positive and negative voltages](http://www.eeworld.com.cn/circuit/upload/366500091e40d5d1e3c0e72a60212ceb/f6b5c266c4a8191aa5bd4788ed88df08.jpg)
- How to Make a Soft Latch Circuit
- In-depth analysis of DC-AC converter inverter
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Single-power supply circuit for ISO122P/ISO124
- Driving circuit that controls LED brightness using PWM signal
- Principles and precautions of active discharge circuit
- How to use SBR to improve power conversion efficiency
- Low cost and high performance LED constant current power supply
- Constant current charger using light emitting diode as voltage regulator
- LM317T voltage regulation adjustable circuit diagram explanation
- STR5412 power circuit
- Power circuit of STR5412
- Industrial X-ray flaw detector delay control switch circuit diagram
- Fixed and switching hybrid regulated power supply electronic circuit diagram
- Schematic diagram of a sound and light dual control energy-saving switch circuit
- DC 12V to AC 100V inverter power supply circuit design
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Class A power amplifier power circuit
- Antenna amplifier synchronous power supply circuit
