AC 220V power indicator light circuit schematic diagram
Source: InternetPublisher:同住地球村 Keywords: power supply diode AC DIY Updated: 2021/02/02
Many better power strips are equipped with an indicator light. It is simply composed of an indicator light and a resistor. After long-term use, the indicator light will not light up. You can use the circuit below to install and repair it, and of course it can also be used for new installations.
In the picture, a resistor of several hundred kiloohms is used to limit the current and voltage. It is recommended to choose between 200K and 500k. The long-term withstand voltage is DC400V or more. The LED can be Φ3mm or Φ5mm. Other colors are not recommended, mainly red with the highest sensitivity, a few microamps. You can see the light,
V1 cannot be omitted, otherwise the LED life will not be long.
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- An article explains the working principle of the Wheatstone bridge
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- How to identify common mode interference? Methods to eliminate common mode interference
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- RC filter explained in detail
- What are the parts of the fpga design process
- Working principle and truth table of JK flip-flop
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- Littelfuse Low Capacitance TVS Diode Array Analysis
- How to judge the positive and negative poles of diodes
- Schottky and Silicon Carbide Diode Analysis
- Wireless microphone circuit
- Photodiode isolation amplifier circuit diagram composed of ISO212P
- Double voltage rectifier circuit
- Incandescent lamp step-down circuit
- Thyristor cut-off delay circuit 6
- Wiring b of PLC input and output terminals
- Internal structure of MC1411 series Darlington current driverc
